ThinkPad T420 Memory Replacement
  1. ThinkPad T420 Memory Replacement, Unlock the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Unlock the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Unlock the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
    • Unlock the latch locking the battery in the laptop.
    • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
  2. ThinkPad T420 Memory Replacement, Release the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Release the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Release the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
  3. ThinkPad T420 Memory Replacement, Remove the RAM door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the RAM door: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the RAM door: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • EET owners: Your kit has this bit. No purchase needed.
    • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
    • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
    • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
    • Pull the cover up with a fingernail or a nonmarring pry tool.
    • Remove the screw retaining the keyboard.
  4. ThinkPad T420 Memory Replacement, Remove the keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the keyboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop.
    • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
    • Once the keyboard is loose, remove it from the chassis.
  5. ThinkPad T420 Memory Replacement, Disconnect the keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Disconnect the keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Disconnect the keyboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To reinstall the keyboard, refer to the steps in this guide.
    • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
    • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
    • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
  6. ThinkPad T420 Memory Replacement, RAM module - Bottom: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - Bottom: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - Bottom: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the RAM module by pulling the memory retention tabs back.
    • Remove the existing module by pulling the module from the side, at a 90 degree angle.
  7. ThinkPad T420 Memory Replacement, RAM module - keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the plastic cover hiding the RAM module.
    • Unlatch the tabs retaining the memory module.
    • Pull the module out from a 90 degree angle.
crwdns2935229:015crwdne2935229:0
Nick
crwdns2935283:011/10/09crwdne2935283:0
94,601 crwdns2915208:0crwdne2915208:0
crwdns2935297:059crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,702crwdne2935297:0
What tool might one use as a pry?
commander - crwdns2934203:0crwdne2934203:0
The plastic pry tool will also work for the bottom RAM/mSATA part. I can usually get it open without the assistance of pry tools.
Nick -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 19,866
