ThinkPad T420 Memory Replacement
    1. ThinkPad T420 Memory Replacement, Change note: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ThinkPad T420 Memory Replacement, Change note: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
    1. ThinkPad T420 Memory Replacement, Unlock the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Unlock the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Unlock the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
      • Unlock the latch locking the battery in the laptop.
      • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
    2. ThinkPad T420 Memory Replacement, Release the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Release the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Release the battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
    1. ThinkPad T420 Memory Replacement, Remove the RAM door: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the RAM door: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the RAM door: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • EET owners: Your kit has this bit. No purchase needed.
      • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
      • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
      • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
      • Pull the cover up with a fingernail or a nonmarring pry tool.
      • Remove the screw retaining the keyboard.
    2. ThinkPad T420 Memory Replacement, Remove the keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Remove the keyboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the laptop.
      • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
      • Once the keyboard is loose, remove it from the chassis.
    3. ThinkPad T420 Memory Replacement, Disconnect the keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Disconnect the keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, Disconnect the keyboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To reinstall the keyboard, refer to the steps in this guide.
      • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
      • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
      • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
    1. ThinkPad T420 Memory Replacement, RAM module - Bottom: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - Bottom: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - Bottom: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unclip the RAM module by pulling the memory retention tabs back.
      • Remove the existing module by pulling the module from the side, at a 90 degree angle.
    1. ThinkPad T420 Memory Replacement, RAM module - keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - keyboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ThinkPad T420 Memory Replacement, RAM module - keyboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the plastic cover hiding the RAM module.
      • Unlatch the tabs retaining the memory module.
      • Pull the module out from a 90 degree angle.
crwdns2935229:016crwdne2935229:0
Nick
crwdns2935283:011/10/09crwdne2935283:0
106,311 crwdns2915208:0crwdne2915208:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0335crwdne2931471:0
crwdns2935297:08,260crwdne2935297:0
What tool might one use as a pry?
commander - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The plastic pry tool will also work for the bottom RAM/mSATA part. I can usually get it open without the assistance of pry tools.
Nick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 262
crwdns2942667:0crwdne2942667:0 22,547
