The Claw Circuit Board Replacement
Alain Pierre
crwdns2944107:0crwdnd2944107:0Alain Pierrecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 11, 2024crwdne2944111:0
20 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If you are experiencing total failure of your claw machine and you are sure that the batteries and power switch are functioning properly, it is likely that the circuit board is damaged. In this case you will need to open the bottom cover of the claw machine in order to access and remove the faulty board. This replacement guide provides user friendly steps to assist users in the replacement of the circuit board.
crwdns2944105:0crwdne2944105:0
  1. The Claw Circuit Board Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place The Claw in upright position with controls facing you.
  2. The Claw Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently flip The Claw machine upside down with the controls facing you.
  3. The Claw Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
  4. The Claw Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Claw Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
  5. The Claw Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: How To Solder and Desolder Connections.
  6. The Claw Circuit Board Replacement, Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have removed the bottom cover you should have clear access to the circuit board.
    • Locate the circuit board in the bottom of The Claw machine.
  7. The Claw Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screws that hold the circuit board in place.
  8. The Claw Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to turn off the device and remove the batteries before reaching into the device with your hands or any metal tools.
    • Using a Phillips #1 screwdriver, remove the four 6mm that hold the circuit board in place.
    • You will also need to cut all of the wires leading to the circuit board to completely remove it.
  9. The Claw Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circuit board.
    • The removal of the circuit board requires the cutting of existing wires and soldering new wires to the new board. For help with soldering reference: How To Solder and Desolder Connections.
    does anyone have electronics schematic?
    our board is KS015-A2
    Branimir - crwdns2934203:0crwdne2934203:0
Alain Pierre
crwdns2935283:003/22/16crwdne2935283:0
1,188 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-8, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 4-8, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S4G8
crwdns2935297:018crwdne2935297:0
crwdns2947412:09crwdne2947412:0
I accidentally cut the wires where the motors are and now can not figure out which go where, is there a diagram or drawling of where each wire goes?
Dyn4mic Universe - crwdns2934203:0crwdne2934203:0
Did you ever find a diagram for this? I would like to have one also….
Nathan Riffel -
Does anybody know where to get the replacement switches for these?
Bill B. - crwdns2934203:0crwdne2934203:0
Same. I am in need of the replacements as well.
Allison Rousseau -
Me too. L/R switch doesn't work need to replace it.
Johnny Annon -
I would also like a wiring diagram for this as well
britney D Bidon - crwdns2934203:0crwdne2934203:0
Red wire coming fm on and off switch is disconnected where does it connect to
David Hernandez 1255 - crwdns2934203:0crwdne2934203:0
Me too! I opened the battery / circuit board area and there wasn't much slack so the red wire pulled off and I can't find where it goes. I wrote to Global Gadgets this week and they kindly replied saying they'd passed my question on to someone. Probably the manufacturer and doubtful I'll hear back. Will post any info if I do.
Pedrao123 -
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 6,727
