Texas Instruments TI-30 XS Multiview Solar Panel Replacement
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
      • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
      • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
      • Lift the metal plate from the battery and set it to the side.
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the spudger (or fingernail) to lift the battery from the black holder.
      • Put the new CR2032 battery in. Never insert a different type of battery!
      • Make sure the positive side of your CR2032 is facing up.
      • Reverse the steps 2 and 1.
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
      • Carefully pull the solar panel away from the calculator, as shown to the left.
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The capacitor might not be discharged. Proceed with caution.
      • Unsolder the three wires from the motherboard.
      • Unsoldering help can be found here.
      • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
Aaron Feinstein
crwdns2935283:010/01/15crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-2, Forte Fall 2015 crwdns2935289:0Cal Poly, Team 11-2, Forte Fall 2015crwdne2935289:0
CPSU-FORTE-F15S11G2
crwdns2935297:036crwdne2935297:0
Do you know where I could get a replacement solar panel for the calculator?
Josh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 3,161
