Texas Instruments TI-30 XS Multiview Battery Replacement
  1. Texas Instruments TI-30 XS Multiview Battery Replacement, Open the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-30 XS Multiview Battery Replacement, Open the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
    I didn’t have a spudger but a flat 3/32” jeweler’s screwdriver worked just as well. Also, the battery slides out the side, nothing to undo. I slid it out using a jeweler’s screwdriver. (Don’t touch any electrical components or traces with the metal tip.) If you’re not sure the battery is good, turn the unit over and see if there is anything displaying, or run a test operation like 2 x 2 etc. to check before putting the back into place.
    Therese S - crwdns2934203:0crwdne2934203:0
  2. Texas Instruments TI-30 XS Multiview Battery Replacement, Open the battery compartiment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Battery Replacement, Eject the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to lift the battery up from the black holder.
    Funktioniert beim 30X Pro Multiview gleich?
    Dihydrogen Dioxide - crwdns2934203:0crwdne2934203:0
    Is a spudger really necessary. I don't have it, just the phillips 00 screwdriver. Do I need to go out and buy one of these?
    Abdullah Siddiqui - crwdns2934203:0crwdne2934203:0
    You can just use a fingernail to open it.
    Jeffrey Johnson - crwdns2934203:0crwdne2934203:0
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Reverse the steps 2 and 1.
    And if the calculator doesn’t turn on if you press “on”,
    press the “reset” button on the back.
    Arne Cl - crwdns2934203:0crwdne2934203:0
    my TI-30XS battery was mounted directly onto the circuit board under a metal clip, the black battery holder doesn't exist at all. Anyway the battery is the still the same CR2032.
    Ole Debess - crwdns2934203:0crwdne2934203:0
    Different revisions of the board. I also had the version you described.
    Pencil43 -
crwdns2935229:020crwdne2935229:0
Nancy Ruiz
crwdns2935283:009/22/15crwdne2935283:0
312 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-2, Forte Fall 2015 crwdns2935289:0Cal Poly, Team 11-2, Forte Fall 2015crwdne2935289:0
CPSU-FORTE-F15S11G2
crwdns2947412:011crwdne2947412:0
Hi, I followed your steps but my battery cover is not in the location that your photo indicates and the cover screws are not visible. There seems to be something covering them?
Why would my battery be situated next to the round black thing and yours is located above it at the top? If the calculator is a TI-XS 30 Multiview why on earth would they vary the orientation of internal components?
(I have had this calculator since 2006 - 12 years - it died this morning and I am disconsolate. Please help me figure out how to take the battery cover off or convince me to dispose of it.) ….I hate throwing away a good machine, even if I need to buy a more up to date graphing machine.
Eric of Ann Arbor
eric@engeltutors.com
Eric Engel - crwdns2934203:0crwdne2934203:0
Please note - My battery screws (the ones that were inside the calculator next to battery) were actually glued over. I had to push the old battery out with my screw driver and push it out manually. It worked though. Glad I didn’t have to toss it, one less thing going into the land-field.
castanedaky36 - crwdns2934203:0crwdne2934203:0
Wait a minute. Why does this calculator need a battery if it has a solar cell. It must be a fake solar cell to deceive.
Julio Lizzo - crwdns2934203:0crwdne2934203:0
It charges the CR2032.
You can shine a light on the panel and remove the battery and the calculator will still work.
Steve Benitah -
It should be mentioned that you should insert a rechargable ML2032 instead of a common non-rechargable CR2032, since the solar panel will recharge the battery and standard CR2032 batteries are non-rechargable.
limsupsinx - crwdns2934203:0crwdne2934203:0
It actually doesn't charge the battery (which is a standard CR2032, as noted on the back of the calculator), it will power the calculator instead of using the power of the CR2032 battery.
Andrew S -
Thank you for the clear instructions! I love this simple scientific calculator and glad to have fixed after 10 years of reliable use. I'm also happy to keep it out of the landfill for now!
Susan Batson - crwdns2934203:0crwdne2934203:0
I just got this calculator and I am unable to lighten the display. I am assuming the battery is either weak.or dead but again - I just got this.
vickis47 - crwdns2934203:0crwdne2934203:0
After turning the calculator on, press the green "2nd" button, then press the "+" button. Continue this until the contrast of the display is to your liking.
Andrew S -
Unfortunately, I replaced the battery with a new one and the calculator still doesn't turn on. Shame.
A 2016 battery can be used if you don't have a 2032. It is thinner, so will not last as long, perhaps only a few years, but has the same voltage.
Happy Zahn - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 38
crwdns2936753:07crwdne2936753:0 275
crwdns2936753:030crwdne2936753:0 1,007
crwdns2942667:0crwdne2942667:0 123,780
