Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement
  1. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
  4. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Front and Back Panels: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry back the metal tabs on the left and right corners of the toaster's front and back metal panels.
    • Pull off the front and back panels of the toaster.
  5. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Inner Heating Panels: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Inner Heating Panels: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry back the metal tabs on the corners of the front and back inner heating panels using an opening tool.
    • Remove both the front and back inner heating panels of the toaster.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
96 032 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 826crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 213
