Tefal GV6760 Effectis Steam Generator Iron Disassembly
  1. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the base of the unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the base of the unit: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the base of the unit: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is what we are going to teardown for repair. Other models of Tefal steam generator irons may have similar construction.
    • First remove the power connector. It is difficult to grab, so you can use a pry tool to remove from base. This is actually optional. When you remove the base the cord comes off and stays in the base.
    • Use a torx 20 bit to remove four screws marked at the base.
  2. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the connector to the handle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the connector to the handle: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the connector to the handle: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the base is off, we can see the inner construction of the iron. The steam generator unit is the large round steel thing with the heater unit and safety sensors on it. This large steel part is now free. If the iron was used very recently, the steam generator may be very hot, so be careful.
    • Remove the cable connector coming from the handle of the iron by pulling it up. Also remove the ground cable marked in the first photo.
    • Locate two plastic tabs that hold the upper cover inside the plastic casing. Second and third photos show the openings that you can use to reach the tabs.
  3. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Release the tabs and remove top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Release the tabs and remove top cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Release the tabs and remove top cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tab that needs to be pried can be seen in the first photo.
    • The second photo shows the bottom of the top cover. See the marked latching tabs on the top cover.
  4. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove more cable connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove more cable connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We need to first remove these connectors to ease the circuit board removal.
    The most difficult part of disassembly is removing the front top plate, which should be between item 4 and 5. I think it should be added how it should be dismantled. Other information is very useful. Thanks.
    Muzaffer TORLAK - crwdns2934203:0crwdne2934203:0
  5. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the control panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the control panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the control panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate two tabs that will help you pry off the control panel.
    • Softly pry the tabs and the control panel will come out when you pull it forward. Be careful there are cables that are attached to the panel and there is not much slack.
  6. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the screws of top decoration panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the screws of top decoration panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are three screws holding the top decoration panel, use a Philips 0 bit to remove them.
    • Now the PCB can be seen, separated from the bottom part and held in place with tabs inside the top decoration.
  7. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the PCB from the top decoration: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the PCB from the top decoration: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the PCB from the top decoration: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the tabs shown in the first and second photos that keep the main PCB in place.
    • Remove the PCB.
    • The power button has a clear plastic insert, be careful not to lose it.
  8. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Give that PCB a very good clean: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Give that PCB a very good clean: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Even though the PCB has conformal coating, it somehow has corrosion formed on it. I have seen this fault at two different irons. I think it is a very common issue.
    • Use 99% isopropyl alcohol and a soft brush to clean the oxidation. In my case I had to use brake cleaner, too. I am not sure if this has damaged the existing conformal coating.
    • If you have access to paint on conformal coating, applying some may be a good idea. I haven't done it.
    • Use a hairdryer to dry the PCB before re-assembly.
    Cleaning the PCB fixed the problem.
    The problem manifested itself as follows: after turning on the iron, it pumped water into the steam generator only once. After reducing the pressure in the tank, the water pump did not start. After cleaning the circuit board (with white spirit... I don't have propanol), everything is fine.
    Thanks to the author of the article.
    Igor - crwdns2934203:0crwdne2934203:0
    Happy to have helped! :-)
    Koray -
  9. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Put the steam generator iron back together: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Put the steam generator iron back together: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Put the steam generator iron back together: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do everything in reverse order and re-assemble the iron.
    • Make sure all connectors are fit snug.
    • Well-done. If the corrosion was not extensive and didn't eat traces, your iron will work properly again. If there is further damage, you will need to repair or replace the board I am afraid.
crwdns2935229:09crwdne2935229:0
Koray
crwdns2935283:003/05/17crwdne2935283:0
1,341 crwdns2915208:0crwdne2915208:0
Very useful! I had no idea about how to remove the top cover.
Daniel-Mircea - crwdns2934203:0crwdne2934203:0
Super! Vous avez expliqué ça très bien. Merci beaucoup 🥳
Mike Williams - crwdns2934203:0crwdne2934203:0
Merci beaucoup. J'ai une centrale vapeur CALOR Effectis, model GV6820. Elle a une conception très très similaire et se démonte de la même façon. Pouvez-vous changer dans le titre du tutoriel "Tefal" par "Tefal ou Calor". Ce serait utile lors de la recherche. Merci.
Gilles Guérin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 7,494
