Teenage Engineering OP-Z Volume Potentiometer Replacement
  1. Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Volume Potentiometer Replacement, Midframe: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  13. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to disconnect the flex cable from the encoder board.
  14. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  15. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  16. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  17. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the highway flex cable off the midframe and remove it.
  18. Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
  19. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
  20. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
  21. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
  22. Teenage Engineering OP-Z Volume Potentiometer Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the volume potentiometer.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
129,009 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,145crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,534
