Use this guide to replace the rubber feet of your OP-Z.
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
Remove the bottom plate including the rubber feet.
Remove the four Phillips #0 screws from the back of the rubber feet.
Separate the front and rear part of the rubber feet from the back cover.
