The rice cooker contains a heating element responsible for heating and cooking the rice while it is turned on. In this guide we will show how to expose the heating element of the Tatung TAC-6G rice cooker and replace it.
Lift the lid and bowl from top of the device
Turn the bowl upside down so that the three legs point upwards
Remove the one 7 mm Phillips screw from the side of the brass panel.
Remove the 6mm Phillips screw that holds the stainless plate.
Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
Using your hands, remove the heating plate that is on top of heating element.
Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
Using, your hands, take out the heating element and replace it with a new one.
where can I buy this heating element? Thanks.
where to buy parts is the problem!!
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
i was able to buy the heating element on ebay!
