TI-84 Plus Silver Edition Battery Spring Replacement
Clayton Rudolph
crwdns2944107:0crwdnd2944107:0Clayton Rudolphcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0May 7, 2024crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide is useful if the battery spring in your calculator has been broken and needs to be replaced. The only requirements are the tools needed to remove the screws, pry the calculator open, and remove and replace the battery spring. All of these tools can be purchased easily. The only hazards that might be seen are damaging the inside electronics of the calculator once it is open so it is best to leave the open calculator in a safe place.
crwdns2944105:0crwdne2944105:0
  1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
  2. TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the calculator open.
    • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
  3. TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery in order to access the battery spring that needs to be replaced.
  4. TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the damaged spring using the tweezers.
  5. TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pick up the new spring with the tweezers.
    • Insert the new spring with the tweezers.
    • Gently push the new spring into place using your finger.
  6. TI-84 Plus Silver Edition Battery Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test by replacing the battery that was taken out to check the connection.
Clayton Rudolph
crwdns2935283:009/15/20crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S3-G3, Willis Fall 2020 crwdns2935289:0University of Memphis, Team S3-G3, Willis Fall 2020crwdne2935289:0
UM-WILLIS-F20S3G3
Hi! So where can I get the spring part?
Aleyson B.Hunter - crwdns2934203:0crwdne2934203:0
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh -
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 808
