System76 Serval WS Cooling Fan Replacement
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 System76 Serval WS Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 System76 Serval WS Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Oliver Anderson
crwdns2935283:003/26/19crwdne2935283:0
289 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G4, Valliere Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G4, Valliere Spring 2019crwdne2935289:0
UMASSD-VALLIERE-S19S1G4
What model of fan would one buy to replace this?
CrustyTrombone - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 913
