Replace the the gyro on your Syma S107 so that it stops self destructing.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
Remove the counterweight bar by removing the screw.
One 10.1mm Phillips #0.
Remove the gyro carriage by removing the following screws:
Two 5.6mm Phillips #0.
Gently remove the broken gyro carriage by pulling up.
Remove blade assembly by simply sliding it up and off the shaft.
Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
Remove the blades from the blade carriage by removing the following screws:
Two 4.7mm Phillips #0.
Remove the following screws:
Two 4.5mm Phillips #0.
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Cheers thanks too this page I fixed problem great , Martin
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Now it flies in an oval pattern wat am I doing wrong?
