This guide shows you how to replace the motherboard in the Surface Studio
Lay the Surface face down on a padded surface
Remove the four rubber feet at each corner concealing the Torx screws
Remove the four Torx screws under the rubber feet.
Two screws on the upper corners are longer than two screws on the lower corners.
Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
Remove five torx screws holding the two fans to the midframe
Remove the two fans
Remove four large torx screws holding the midframe
Remove four small torx screws holding the midframe
Slowly remove the midframe
Detach the connectors for the two fans and the speaker
Remove four spring loaded torx screw labeled 1 to 4
Remove four torx screw labeled 5 to 7
Remove 5mm hex mounting post
Use a spudger to remove the heatsink assembly from the motherboard
Remove three torx screws holding the hard drive brackets
Remove the hard drive and disconnect the SATA/SATA power cable
Lift the black plastic flap attached to the data cable retainer and rotate it away from motherboard.
Pull the data cable out of its socket.
Disconnect the data cable connecting the headphone jack to the SD card slot modular board
Remove three torx screws holding the SD card slot modular board
Remove the SD card slot modular board
Remove a torx screw holding the headphone jack
Remove the headphone jack
Remove a Phillips screw still retaining the power supply
Remove a torx screw retaining the power supply cable
Unplug the power supply from the motherboard
Lift the power supply up and away from the base unit
Remove three torx screws holding the motherboard
Lift the motherboard up and away from the base unit.
Remove three 5mm hex mounting posts
Sir I need help
Microshoft surface studio 2 plus 27”
This device work bud display do not light black screen any idea sir how to fix ???? And Usb keyboard work cap’s look work
Sir i need help
Sir i need help
I have microshoft surface studio 2 plus 27” this device do not display but always work screen black how to fix plz help me sir
Is it possible to DIY to use a full fledged PC tower with this screen? The display would be extremely useful for digital painting and 3d sculpting beyond the life of the computer hardware.
Where can just the mainboard be found? Did some searches on amazon and ebay to no avail. Is there a part number to the i7, 16GB 1TB version that can be looked up?
I would like to find a new motherboard too… 32gb ram though.
