Surface Laptop Studio SSD Replacement
  1. Surface Laptop Studio SSD Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
    Luis Ruiz - crwdns2934203:0crwdne2934203:0
    It appears to be thin plastic with an aluminum coating on the outside. It's easy to remove by poking into the corner by the hinge with a set of tweezers-- the tweezers will pass right through.
    Michael Montalban - crwdns2934203:0crwdne2934203:0
    Ok and how do you reattach it when you're done? I mean is it glued on or how does that work?
    Rika - crwdns2934203:0crwdne2934203:0
  2. Surface Laptop Studio SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the SSD directly out of its socket.
    If the SSD is a 2280 length, then you will need to also remove the carrier bracket (two T3 screws) and use a 1mm plastic washer for it to fit correctly. Leaving the carrier in place will work, but it will cause the screw mount for the original SSD to push against the back of the new SSD and slightly warp the SSD. If the SSD has a thicker PCB, you may not need the 1mm washer.
    slightlyevolved - crwdns2934203:0crwdne2934203:0
Nate Ball
crwdns2935283:002/14/23crwdne2935283:0
708 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G3
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - crwdns2934203:0crwdne2934203:0
Can you fit a full sized ssd or only the short ones?
Omega_o7 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 75
crwdns2936753:030crwdne2936753:0 278
crwdns2942667:0crwdne2942667:0 10,866
