Surface Laptop Studio Battery Replacement
  1. Surface Laptop Studio Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
    Luis Ruiz - crwdns2934203:0crwdne2934203:0
    It appears to be thin plastic with an aluminum coating on the outside. It's easy to remove by poking into the corner by the hinge with a set of tweezers-- the tweezers will pass right through.
    Michael Montalban - crwdns2934203:0crwdne2934203:0
    Ok and how do you reattach it when you're done? I mean is it glued on or how does that work?
    Rika - crwdns2934203:0crwdne2934203:0
  2. Surface Laptop Studio Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.c
Nate Ball
crwdns2935283:002/14/23crwdne2935283:0
708 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G3
crwdns2935297:013crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - crwdns2934203:0crwdne2934203:0
Are the rubber feet re-attachable to the laptop after repairs?
The what you need section should also mention Surface Laptop Studio Cosmetic Plate - Genuine, possibly as an optional part.
Ronno Das - crwdns2934203:0crwdne2934203:0
Great point, Ronno! We added that to the parts list. Thanks for your comment.
Connor -
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 117
crwdns2936753:030crwdne2936753:0 414
crwdns2942667:0crwdne2942667:0 8,201
