SteelSeries Stratus Duo Trigger Button Covers Replacement
  1. SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the sticker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the sticker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. SteelSeries Stratus Duo Trigger Button Covers Replacement, Unscrew the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. SteelSeries Stratus Duo Trigger Button Covers Replacement, Reposition the back cover assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Reposition the back cover assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Reposition the back cover assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the interconnect cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the interconnect cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the interconnect cable: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. SteelSeries Stratus Duo Trigger Button Covers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the battery cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the battery cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the battery cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the back cover assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover assembly.
  8. SteelSeries Stratus Duo Trigger Button Covers Replacement, Unscrew the thumbsticks board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.8 mm-long screws securing the thumbsticks board.
  9. SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the thumbsticks board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the thumbsticks board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Disconnect the thumbsticks board: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the thumbsticks board with your hand and disconnect it by pulling it straight up and out of its socket on the mainboard.
    • Remove the thumbsticks board.
    • For reassembly make sure to correctly align the ten pins with their socket on the mainboard.
  10. SteelSeries Stratus Duo Trigger Button Covers Replacement, Unscrew the mainboard assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 6.8 mm-long screws securing the mainboard assembly to the case.
  11. SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the mainboard assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the mainboard assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the mainboard assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hand to remove the mainboard assembly by tilting it out of the plastic cover.
  12. SteelSeries Stratus Duo Trigger Button Covers Replacement, Unscrew the trigger button covers: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 7.2 mm-long screws securing the trigger button covers to the mainboard.
  13. SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the trigger button covers: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the trigger button covers: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Stratus Duo Trigger Button Covers Replacement, Remove the trigger button covers: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the trigger button covers off of their shoulder button breakout boards.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58.179 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.066crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 385
