SteelSeries Nimbus+ Controller Battery Replacement
crwdns2869540:0crwdne2869540:0: 2.6K
3
25
87
2,627
crwdns2955950:0crwdne2955950:0: 2
crwdns2960002:01crwdne2960002:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Use this guide to replace a worn out or dead battery in a SteelSeries Nimbus+ controller.
For your safety, discharge the battery below 25% before disassembling your controller. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling your device.
    1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
      • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The back cover is held in place by plastic clips.
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
      • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back cover assembly.
    1. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The battery is held in place by mild adhesive.
      • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Use the opening pick to carefully pry up the battery and loosen the adhesive.
    2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Make sure to align the battery and the back cover of the controller correctly during reassembly.
For optimal performance, calibrate your newly installed battery after completing this guide.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
69,392 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2935297:072,955crwdne2935297:0
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 87
crwdns2959996:0crwdne2959996:0 2,627
