Follow this guide to access and remove the main circuit board from the headset housing.
Lift the edge of the cushion and pull out slightly.
Work your way around the cushion until it comes off completely.
Repeat for the other cushion.
Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
Lift the speaker off the headset to expose the circuit board.
Remove the three 5mm screws using a Phillips #0 driver head.
Lift the circuit board out of the plastic housing.
I am worried about damaging the board while lifting the board out, there is quite some resistance, do I apply more pressure?
any idea where i can buy the circuit parts to both side?
any idea where i can buy Circuit Board Replacement for both side? please
What's the problem that requires circuit board replacement? My left speaker doesn't work checked and all wires connected. Wondering if the circuit board fixes that
I do not believe that my Arctis 7 uses Phillips #0 it looks to be some kind of tamper proof start bit, do you know what kind that would be?
Jerrett Smith - crwdns2934203:0crwdne2934203:0
