Prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to remove the complete right bumper assembly (R1) in a Steam Deck.
Power down your Steam Deck and unplug any cables.
crwdns2935267:0crwdne2935267:0FixMat$31.41
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Remove the board shield.
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Place the flat end of a spudger onto the inside edge of the trigger's right clip.
Pivot the trigger clip out, away, and up from the peg to unlatch it.
Remove the right trigger.
Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
Remove the right trigger bracket.
Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
Use a pair of tweezers to slide the cable out of its connector.
Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
Remove the right thumbstick.
Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
If any connectors are covered with tape, use a pair of tweezers to remove it.
Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
Disconnect the action buttons cable.
Disconnect the touchpad board cable.
Disconnect the touchpad cable.
Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
Use a Phillips driver to disconnect the four screws securing the right button board:
Three 5.2 mm screws
One 3.9 mm screw
Remove the right button board.
Use a Phillips driver to remove the two 5.2 mm screws securing the right bumper assembly.
Remove the right bumper assembly.
