Flip the camera upside down, and observe where the battery door and switch are located on the camera.
Slide the switch over to the right side to open the battery door.
Depress the blue lever to allow the battery to pop out slightly.
Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the blunt tweezers, remove the blue ribbon cable.
Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
On my A7 the screw shown first top right was a different thread to the other three, take care to put back in the correct place
Lift the metal plate and LCD screen away from the camera body.
Detach the amber ribbon cable from the motherboard.
13단계에서 14단계로 오는사이에 마더보드의 왼쪽 아래부분 나사 푸는 부분이 누락된것 같습니다. 아래 20단계에서 억늡한 나사 2개 이외에 아래쪽 2개를 더 푸는것을 추가해야 합니다.
그리고 8단계 2번째 사진의 나사는 풀 필요가 없는 나사인데.. 왜 풀어야 하는지요??
Peel off the small adhesive tape located on the top right side of the motherboard.
Remove the exposed ribbon cable by using the iFixit opening tools
Peel off the large black protective adhesive from the motherboard.
Remove the four visible ribbon cables by using the spudger.
For SD card slot replacement: Remove the bottom right flex cable. There will be a hole under the cable to access a screw in the battery compartment, which holds on the grip. Remove the screw. Remove the one remaining screw in the corner of the battery compartment. The grip should now come loose. Remove the grip. Remove the two screws holding the SD card board on. Disconnect the small two wire cable from the top of the board. The board should now slide out. Disconnect the flex cable from the old board and connect to the new board for reinstall.
I did this for a Sony A7S and all is working well.
Remove the one U.FL plug by using the spudger.
Using the spudger, remove the four remaining ribbon cables.
For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
on my A7 there was three 5mm course thread screws marked orange, two were in the holes at the bottom of the main board
Lift the motherboard from the camera body.
Remove the two visible ribbon cables by using the forceps.
The manual identifies the motherboard as sy-1022. It has several surface mount fuses. Did you repair your board by replacing these fuses or swap out the board. A repair tech in the US said that when a board is swapped out and data cannot be recovered from the original board, special software is needed to get the camera operational. Did you run into that issue? Also- did you replace the board's lithium battery?
Gently pull the viewfinder out ouf the housing
Remove the two M 1.5x2mm screws.
Remove the M1.5x4mm screw.
Remove the two M1.5x4mm screws.
Pull of the grip to the front
Pull the grip of to the front
이 단계(26)를 22단계 뒤에 해야 합니다. 탑을 제거하기전에 이부분을 먼저제거해야 합니다. 안그러면 flex cable이 끊어지기 쉬워요.. 아주 가늘거든요..
Grab the top part on the sides and gently remove it to the top direction.
Remove the two M1.5x4mm self tapping and the M1.5x4mm screw.
Pull of the small metal plate.
Remove the cable from the ribbon connection.
Remove the adapter cable.
Remove the three M1.5x4mm self tapping screws.
Gently pull of the back cover. Pay attetion to the ribbon cables.
Remove the tripod thread.
Remove the M1.5x2mm screw.
Remove the connector on the side of the camera.
Pull out the battery housing to the back.
Remove the two M1.5x5mm screws
Remove the copper plate from by lifting it from the right side.
Remove the M1.5x5mm screw.
Gently remove the sensor board.
Remove the M1.5x5mm self tapping screw.
Remove the four small support plates.
Remove the front cover of the camera.
Remove the three M1.5x4mm screws.
Lift of the shutter assembly.
Remove the special screw on the backside of the shutter.
Remove the shutter curtain from the shutter drive.
Done :)
Incomplete /slightly incorrect guide, missed some connectors on the board as in the photos they were already unplugged so it almost caused me to rip a ribbon cable.
Could you please let me know the exact step where the instructions are missing so that the missing information can be added? I hope this guide was still from value for you and that you could repair your gear!
Marco -
Very nice guide, it helped me repair my A7 locked shutter (which mechanism was blocked by a small piece of metal). On step 19 there was a small ribbon that was missing in your guide, you can see it is already removed on the top left. There were a couple more small details, but overall such fantastic help, thank you!!
Found this after I done the job. Shame I did not search more. How to return count to zero after fitting the new unit? The count shows previous total, I hoped for zero to show. tia.
