Sony a7 LCD Screen Replacement
  1. Sony a7 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera upside down, and observe where the battery door and switch are located on the camera.
    • This replacement guide is using a cardboard and tape placeholder to simulate the battery, battery door, and switch.
  2. Sony a7 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the switch over to the right side to open the battery door.
  3. Sony a7 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Depress the blue lever to allow the battery to pop out slightly.
  4. Sony a7 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the camera.
    • Make sure to hold onto the battery firmly when removing it from the camera, as it could slide out and fall.
  5. Sony a7 LCD Screen Replacement, Rear Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
    • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
  6. Sony a7 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
  7. Sony a7 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
  8. Sony a7 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four M 1.5x2mm screws.
  9. Sony a7 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
  10. Sony a7 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the blunt tweezers, remove the blue ribbon cable.
    • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
  11. Sony a7 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
  12. Sony a7 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
    On my A7 the screw shown first top right was a different thread to the other three, take care to put back in the correct place
    David Zhecheva-Hamilton - crwdns2934203:0crwdne2934203:0
  13. Sony a7 LCD Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the metal plate and LCD screen away from the camera body.
  14. Sony a7 LCD Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the amber ribbon cable from the motherboard.
    13단계에서 14단계로 오는사이에 마더보드의 왼쪽 아래부분 나사 푸는 부분이 누락된것 같습니다. 아래 20단계에서 억늡한 나사 2개 이외에 아래쪽 2개를 더 푸는것을 추가해야 합니다.
    그리고 8단계 2번째 사진의 나사는 풀 필요가 없는 나사인데.. 왜 풀어야 하는지요??
    bongjae kim - crwdns2934203:0crwdne2934203:0
  15. Sony a7 LCD Screen Replacement, LCD Screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 LCD Screen Replacement, LCD Screen: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four M1.5x2mm screws with a PH00 Phillips screwdriver.
  16. Sony a7 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit opening tools, pry the plastic casing off the back of the LCD screen.
    • It may be difficult to remove the backing from the LCD, so it does require a fair amount of cautious pressure.
  17. Sony a7 LCD Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Seperate LCD screen from its metal backing.
  18. Sony a7 LCD Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable that connects the LCD screen to the camera by using the iFixit opening tools.
    • In order to successfully remove the ribbon cable, it will be necessary to lift up on the connector.
    Where do I find a replacement screen
    Taslim Rahman - crwdns2934203:0crwdne2934203:0
Jeffrey Coleman
crwdns2935283:001/14/20crwdne2935283:0
1 346 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S16-G2, Branham Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S16-G2, Branham Spring 2020crwdne2935289:0
ERAU-BRANHAM-S20S16G2
Hello,
If by “isn’t finished” you mean that the instructions do not contain the steps to put the camera back together, this was done in the hope that the user would follow the steps in a reverse order to put the camera back in one piece.
Best.
Jeffrey Coleman -
completely-incomplete tutorial in 4 steps
I hope you never made a plane like this
Gue - crwdns2934203:0crwdne2934203:0
Hello there,
Thank you for your constructive comment. The criteria we needed to meet for this project was to provide instruction on iFixit guides for how to remove various parts on the device. We were being evaluated on the content pertaining to our writing and not the technical depth of the guide. Furthermore, we did not have a vested interest in replacing the screen nor did we have another screen to replace it with. In your rush to make a rude comment, you might have missed the end of the guide where it states that in order to reassemble you must follow the steps we provided in the reverse order. Reverse means doing something in the opposite direction.
Regards.
Jeffrey Coleman -
Thank you! Appreciated the clear instructions.. I have one question is the new screen price range is around 20 to 30$ ? I find it cheap to be true but at the same time I hope it’s 😄
mohamedsayed7 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 251
crwdns2942667:0crwdne2942667:0 19,020
