Sony Xperia Z1s Battery Replacement
    1. Sony Xperia Z1s Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the opening pick in the crease between the rear cover and the body of the phone.
      • Pry along the edge to lift and remove the back cover.
    2. Sony Xperia Z1s Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
      • Remove the panel by grabbing its bottom edge and lifting upwards.
    3. Sony Xperia Z1s Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the opening pick to pry off the battery flex cable.
    4. Sony Xperia Z1s Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
    5. Sony Xperia Z1s Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Firmly press the suction cup onto the battery.
      • Pull the battery out using the suction handle.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Matthew Klengson
crwdns2935283:009/30/21crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
Clemson, Team 4-4, Hunter Fall 2021 crwdns2935289:0Clemson, Team 4-4, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S4G4
crwdns2935297:057crwdne2935297:0
Step 1 - The gap is too small to simply use the pick. The suction tool also did not provide a big enough gap to get the pick in. In order to get the pick in I had to heat up the back and use the suction cup in order to get the pick. Then moved the pick around the perimeter to pull of the back. The battery was attached to the back with two glue strips. I unpluged the battery ribbon cable and got the glue off using the two pull tabs that were attached to the glue.
The rest of the steps were non existent in my case. Hope this reply helps
MrKoszmaro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 731
