Sony Xperia Z1 Compact Battery Replacement
kinan badr
crwdns2944107:0crwdnd2944107:0kinan badrcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 13, 2019crwdne2944111:0
crwdns2931287:050crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The Battery of the phone can become worn with continued use. This guide will show you how to remove the Battery of Sony Xperia Z1 Compact.
crwdns2944105:0crwdne2944105:0
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z1 Compact Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    The replacement batteries probably come without the new NFC sticker, so you’ll have to transfer it from the original one to the replacement. This can be easily done with an iPlastix and a good amount of isopropyl alcohol. Do this carefully.
    Stefano Restuccia - crwdns2934203:0crwdne2934203:0
  6. Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the device
crwdns2935229:012crwdne2935229:0
kinan badr
crwdns2935283:009/21/17crwdne2935283:0
386 crwdns2915208:0crwdne2915208:0
Washington State, Team S4-G1, Phelps-Hillen Fall 2017 crwdns2935289:0Washington State, Team S4-G1, Phelps-Hillen Fall 2017crwdne2935289:0
WSU-PHELPS-HILLEN-F17S4G1
crwdns2931471:06crwdne2931471:0
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - crwdns2934203:0crwdne2934203:0
What is the Ariel stuck on the battery ?
Tony - crwdns2934203:0crwdne2934203:0
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo -
crwdns2942667:0crwdne2942667:0 11,827
