Sony Xperia XZ2 LCD Screen Replacement
  1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
    Hi my sony XZ2 NOT HAVE light lcd i need to ic light lcd
    Sayed Latif - crwdns2934203:0crwdne2934203:0
  3. Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
    It doesn't look like it, but this is a tricky step. The bracket is a small and fragile part, easily broken (happened to me), even when using the right tool, and almost impossible to repair. Make sure to go easy when grabbing it!
    Célestin Taramarcaz - crwdns2934203:0crwdne2934203:0
  5. Sony Xperia XZ2 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the connector by using a spudger to pop it off.
crwdns2935229:08crwdne2935229:0
Matthew Ionescu
crwdns2935283:001/24/19crwdne2935283:0
424 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G5, White Winter 2019 crwdns2935289:0Cal Poly, Team S19-G5, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S19G5
Worked perfectly fine for my xz2 compact
Maria Schrenk - crwdns2934203:0crwdne2934203:0
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - crwdns2934203:0crwdne2934203:0
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 10,331
