This guide covers the Sony Xperia XZ Premium battery removal. This process involves removing the back panel, frame, and motherboard. This is a time-consuming process and should not be rushed, so make sure you have ample time set aside.
Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
Take hold of the back panel with your fingers and remove.
Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
Remove nine 3.9mm Phillips #000 screws.
Place the spudger under the top left corner frame piece and lift to loosen.
Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
Place the spudger under the bottom left frame piece and lift to loosen it.
Grab hold of bottom left frame piece with your fingers and lift gently.
Place the spudger under the top right frame piece and lift to loosen it.
Grab hold of the top right frame piece with your fingers and lift.
Insert your nail under the top left connector and push to disconnect it.
Grab hold of the metal part of the connector with your fingers and lift.
Insert your nail under the metal part of the bottom left connector.
Push the bottom left connector with your finger to disconnect it.
Insert your nail under the center topmost connector and push to loosen it.
Grab hold of the top connector with your fingers and lift to disconnect it.
Insert your nail under the metal tab of the connector above the battery and push to loosen it.
Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
Insert spudger in the gap above the battery and lift to loosen the motherboard.
Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
Grab hold of the motherboard with your fingers and lift it out of the phone gently.
Insert the spudger under the battery and push to loosen it from the adhesive.
Insert and push the spudger underneath the other sides of the battery to further loosen it.
Use the plastic card to push under the battery to further remove the adhesive.
Lift the battery with your fingers and pull it out.
crwdns2935229:08crwdne2935229:0
個人的意見を書きます。まず最初にこの手順はあくまでもバッテリーを取り外すだけの手順書です。作成者がこの手順書を部分的に書き直さない限り作業事故によっては「ボリューム パワースイッチフレックスケーブル」、「nfcアンテナ」、「イヤホンジャック フレックスケーブル」、最悪「マザーボード」をも交換する羽目になる事を視野に入れて作業した方がいいです。それらの注意書きがないのが残念です。
「ボリュームパワースイッチフレックスケーブル」と「nfcアンテナ」はバッテリーに接着されています。特にnfcアンテナの黒い部分は恐らくアンテナの一部と思われ奇麗に剝がそうとしても絶対に破損しますので交換必須です。
貴重なご意見、ありがとうございました。
手順ありがとうございます。
手順25の前後でで左上側のコネクタを外す手順がなかったので見事に切りました。
他、海外動画と比較していくつか手順がすっ飛んでたので、注意書きはした方がよいと思いました。
詳細を報告いただきありがとうございました。手順25の前後の作業については修理ガイド担当者に付け足しの必要を伝えておきます。コネクタを破損させてしまい申し訳ありません。少し時間がかかるかもしれませんが、貴重な情報は英語と日本語の修理ガイドに反映させていただきます。御礼まで。
