Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement
Jacob Jung
crwdns2944107:0crwdnd2944107:0Jacob Jungcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0May 7, 2024crwdne2944111:0
crwdns2931287:030crwdne2931287:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
This guide will show you how to replace the LCD display touchscreen digitizer for your Sony Xperia XA1 Ultra if the display is cracked or unresponsive. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws, while tweezers and a spudger are needed to remove different components of the phone.
crwdns2944105:0crwdne2944105:0
  1. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Back Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Back Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
    How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
    Kyle Ladtkow - crwdns2934203:0crwdne2934203:0
  2. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
    Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
  3. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
    sure that there is adhesive tape on backcover?
    where should it tape on at the device inside?
    looks more like only plugged together`?
    Alexander H - crwdns2934203:0crwdne2934203:0
  4. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
    Period missing for first point.
  5. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
    Can you clarify what should be repeated in this step?
    Tiffany Dang - crwdns2934203:0crwdne2934203:0
  6. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the two pieces of black tape covering the battery with your hands.
  8. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
    Grammar, consider rewording. “Use the iFixit Opening Tool to remove the flexible orange strip which is connected to the battery from the motherboard” or “Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard” or another alternative depending on your intended meaning.
    exelente, a melhor aula de celular que eu vi.
    wmestrecamaleao - crwdns2934203:0crwdne2934203:0
  9. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the iFixit Opening Tool underneath the battery.
    • Remove the battery by pulling up on the iFixit Opening Tool.
  10. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Antenna Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Antenna Module: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
    That is not the antenna module !!!
    ptbgn - crwdns2934203:0crwdne2934203:0
  11. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your iFixit Opening Tool underneath the antenna module.
    • Lift up gently with the iFixit Opening Tool to remove the antenna module.
    • The antenna module may be difficult to remove.
    Maybe add a caution that the module is hard to take off
    Could use better explanation on how to take off
    “to take off piece” change to take off the piece? Or even be specific, “pull with your hands to remove the module.”
    also the picture makes it look as if you flip the antenna board over but it needs to be pulled up from the phone as if you bend it over it will break
    Andrew Bromfield - crwdns2934203:0crwdne2934203:0
  12. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Front Camera: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Front Camera: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your iFixit Opening Tool underneath the front camera and gently lift up.
    • Remove the front camera by lifting the front camera up with your hands.
    The second part of this NEEDS an action shot
  13. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Headphone Jack: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Headphone Jack: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4mm T5 screw connecting the headphone jack to the panel.
  14. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your iFixit Opening Tool to lift and disconnect the headphone jack connector piece.
    • The small black piece connected to the headphone jack that is holding the single screw in place has broken off in the device shown.
    “use your iFixIt Opening Tool to lift (the) head phone jack…”
  15. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Back Camera: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Back Camera: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your iFixit Opening Tool between the back camera and the motherboard and gently lift up.
    • Lift up with the iFixit Opening Tool until the back camera is removed from the device.
  16. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Motherboard: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, Motherboard: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm T5 screws connecting the motherboard to the device.
    Only the bottom two screws for this part need to be removed; the top two were removed with the antenna module
  17. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your flat head tweezers to remove the black wire connected to the motherboard.
    • Use your flat head tweezers to remove the white wire connected to the motherboard.
    • There are only two wires connected to the motherboard.
    The text should locate the wires better
  18. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your iFixit Opening Tool to remove the main flex (the middle orange tab) from the motherboard.
    • Use your iFixit Opening Tool to remove the power button flex (the left orange tab) from the motherboard.
    The text should be able to locate the flexes on their own
  19. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge your iFixit opening tool under the motherboard.
    • Lift up with your iFixit Opening Tool to lift the motherboard from the device.
  20. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, LCD Display Touchscreen Digitizer: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement, LCD Display Touchscreen Digitizer: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge your flathead tweezers under the earpiece.
    • Lift up with your flat head tweezers to remove the earpiece from the device.
  21. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge your flathead tweezers under the flashlight module.
    • Lift up with your flat head tweezers to remove the flashlight module from your device.
    where are the steps and pictures to remove the five screws from the plastic module on the bottom of the phone covering the charging port PCB board
  22. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the power flex from the charging port PCB board with your flathead tweezers.
    • Lift up with your flathead tweezers to remove the power flex from the charging port PCB board.
  23. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the vibration motor connected to the charging port PCB board with your flathead tweezers.
    • Lift up with your flathead tweezers to remove the vibration motor.
  24. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the black wire connected to the charging port PCB board with your flathead tweezers.
    • Pull up on the black wire with your flathead tweezers to disconnect the black wire from the charging port PCB board.
  25. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the white wire connected to the charging port PCB board using your flathead tweezers.
    • Pull up on the white wire with your flathead tweezers to disconnect the white wire from the charging port PCB board.
  26. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge your iFixit Opening Tool under the charging port PCB board.
    • Pull up with your iFixit Opening Tool to remove the charging port PCB board.
  27. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 4mm T5 screws connecting the side panel to the power button flex cable.
  28. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to grab the side panel of the device.
    • Pull your hands away from the device to remove the side panel.
  29. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 4mm T5 screws connecting the SD card side panel to the device.
  30. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SD card side panel from the device by grabbing the SD card side panel with your hands and sliding the SD card side panel away from the device.
  31. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the two pieces of black tape holding down the battery with your hands.
    • Lift up with your hands to remove the two black pieces of tape that hold down the battery.
  32. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the power button flex with your hands.
  33. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white wire from the device using your hands.
  34. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black wire from the device using your hands.
  35. Sony Xperia XA1 Ultra LCD Display Touchscreen Digitizer Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD Display Touch Screen Digitizer should be the only part left.
Jacob Jung
crwdns2935283:004/18/18crwdne2935283:0
1,429 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G3, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S16-G3, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S16G3
Thanks for the help! Any chance you know where to get the side panels/bars? searched everywhere and cant find them
Taken Out - crwdns2934203:0crwdne2934203:0
Any chance one can replace the outta glass only? touch feature still works :(
Musa Zwane - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,976
