Sony Xperia Sola Battery Replacement
  1. Sony Xperia Sola Battery Replacement, Lay the phone as shown.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Sola Battery Replacement, Lay the phone as shown.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  2. Sony Xperia Sola Battery Replacement, Remove the screws.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove the screws.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove the screws.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
  3. Sony Xperia Sola Battery Replacement, Remove bottom white cover.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove bottom white cover.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the bottom white cover by using the opening tool as a lever.
  4. Sony Xperia Sola Battery Replacement, Remove more screws.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove more screws.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the 2 additional screws, using the Torx screwdriver, that are revealed. These are marked as shown.
  5. Sony Xperia Sola Battery Replacement, Remove black cover.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove black cover.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  6. Sony Xperia Sola Battery Replacement, Disconnect the battery's circuit.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  7. Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  8. Sony Xperia Sola Battery Replacement, Remove the additional power circuit.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  9. Sony Xperia Sola Battery Replacement, Repeat for the circuit on the top end of the battery.: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Sola Battery Replacement, Repeat for the circuit on the top end of the battery.: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to lift up on the circuit located at the top left.
  10. Sony Xperia Sola Battery Replacement, Remove the motherboard.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  11. Sony Xperia Sola Battery Replacement, Remove and replace the battery.: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove and replace the battery.: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Sola Battery Replacement, Remove and replace the battery.: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove battery, slide a flat object under the battery and lift. The plastic opening tool will be the best tool for this.
    • It is possible that the battery may be glued onto the phone. If this is the case, use isopropyl alcohol or adhesive remover underneath the battery to soften the adhesive, then use a suction cup to lift the battery out.
    • If that doesn't work, use low heat to soften the glue to allow removal without breaking the battery. To heat the glue, use a simple hair dryer, but be very careful as not to overheat the phone and damage any components.
    • Using heat on a battery for too long can be dangerous and can also potentially damage other parts of the phone.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler. For optimal performance, calibrate your newly installed battery after completing this guide.
Cary Drew
crwdns2935283:009/25/14crwdne2935283:0
866 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 1-1, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S1G1
Thanks, battery successfully changed :-)
martinslunecko - crwdns2934203:0crwdne2934203:0
Thanx will do that when i get areplacement battery!
ndiwenijb - crwdns2934203:0crwdne2934203:0
hello where i can find a new battery ?
minigamer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 3,345
