Sony WH-1000XM5 Charging Board Replacement
  1. Sony WH-1000XM5 Charging Board Replacement, Earpads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement, Earpads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement, Earpads: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Place the edge of an iFixit opening tool under the earpad cushion.
    • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
  2. Sony WH-1000XM5 Charging Board Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Phillips #000 Screwdriver
    $5.49
    • Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
    • There should be a piece of grey foam you can simply remove to uncover the centre 4 screws.
    • Flip the headphones to the other side and slow lift up the back plastic cover piece.
    • Gently remove the touch sensor's ribbon cable by pulling it out evenly from the main board.
  3. Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the touch pad.
    • Pull out the battery, then disconnect it.
  4. Sony WH-1000XM5 Charging Board Replacement, Power Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the main wire and all ribbons from the power board.
  5. Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two black 1.6mm Phillips screws holding the power board down.
    • Carefully lift the power board from the unit.
  6. Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin soldering, note the following safety precautions:
    • Always unplug, turn off, and remove power sources before soldering.
    • Do not touch the metal part of the soldering iron! The soldering iron can heat up to over 310°C (600°F).
    • Be extremely careful when you are soldering/desoldering lithium-polymer battery wires! You can easily short the battery with solder or your tools, resulting in battery damage and a fire hazard.
    • Plug in the soldering iron and wait 1-3 minutes for it to heat up.
    • Place the flat side of the soldering iron on the 2 globs of metal for 2-3 seconds as shown.
    • While the globs are still hot, use your tweezers to carefully detach the black and red wires from the power board.
  7. Sony WH-1000XM5 Charging Board Replacement, Charging Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement, Charging Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement, Charging Board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the blue sticky strips to the side.
    • Use a spudger to lift up the dark gray mesh from the back plastic part.
    • Use a Phillips #000 screwdriver to remove the 1.6 mm screw in the center.
    • Carefully pull the ribbons through.
  8. Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM5 Charging Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the 1.6 mm black screw on the charging board.
Michel Garcia
crwdns2935283:002/25/25crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-3, Frey Spring 2025 crwdns2935289:0University of Kentucky, Team 1-3, Frey Spring 2025crwdne2935289:0
UKY-FREY-S25S1G3
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 201
