Sony WH-1000XM5 Battery Replacement
  1. Sony WH-1000XM5 Battery Replacement, Earpads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Battery Replacement, Earpads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Battery Replacement, Earpads: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the edge of an iFixit opening tool under the earpad cushion.
    • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
  2. Sony WH-1000XM5 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM5 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
    • There should be a piece of grey foam you can simply remove to uncover the centre 4 screws.
    • Flip the headphones to the other side and slow lift up the back plastic cover piece.
    • Gently remove the touch sensor's ribbon cable by pulling it out evenly from the main board.
  3. Sony WH-1000XM5 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM5 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the touch pad.
    • Pull out the battery, then disconnect it.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Miranda
crwdns2935283:003/20/24crwdne2935283:0
234 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Santin Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-4, Santin Spring 2024crwdne2935289:0
UMASSD-SANTIN-S24S1G4
Hey folks, thanks for taking the time to layout this procedure. These headphones are amazing, and this really helps me get my friends onboard.
placebomessiah - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 31
crwdns2936753:07crwdne2936753:0 170
crwdns2936753:030crwdne2936753:0 752
crwdns2942667:0crwdne2942667:0 8,156
