Sony WH-1000XM4 Touch Sensor Replacement
  1. Sony WH-1000XM4 Touch Sensor Replacement, Touch Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Touch Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • Repeat around perimeter of ear pad until it is loose.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Touch Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right ear pad.
  4. Sony WH-1000XM4 Touch Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the foam liner from the right ear cup's speaker.
  5. Sony WH-1000XM4 Touch Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the right ear cup cover.
  6. Sony WH-1000XM4 Touch Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the right ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with the touch cable.
  7. Sony WH-1000XM4 Touch Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
    • Remove the ear cup cover with the touch sensor attached.
    • The green touch sensor circuit board is glued to the ear cup cover.
    • Repeat steps in reverse order to reassemble after replacing the touch sensor.
Spencer Decker
crwdns2935283:011/09/23crwdne2935283:0
523 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-1, Harley Fall 2023 crwdns2935289:0IUPUI, Team 2-1, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S2G1
Bonjour, le titre n'est pas bon, ce n'est pas le bon modèle, qui fait référence aux oreillettes sans fil
Brice - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 148
crwdns2942667:0crwdne2942667:0 2,277
