Sony WH-1000XM4 Ear Pads Replacement
  1. Sony WH-1000XM4 Ear Pads Replacement, Place the headphones speakers-up: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Ear Pads Replacement, Create a gap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Create a gap: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
  3. Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  4. Sony WH-1000XM4 Ear Pads Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step around the perimeter of the ear cup to disconnect the remaining clips.
  5. Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left ear pad.
  6. Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When installing a replacement left ear pad:
    • Align the cushion over the speaker and press them firmly together to snap it into place.
    • Press around the entire edge of the cushion, making sure all the clips have engaged.
  7. Sony WH-1000XM4 Ear Pads Replacement, Create a gap: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Create a gap: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
  8. Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Unclip the ear cup: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When the first clip disconnects, you'll hear an audible clicking sound.
  9. Sony WH-1000XM4 Ear Pads Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  10. Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Remove the ear pad: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right ear pad.
  11. Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM4 Ear Pads Replacement, Reassembly tip: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When installing a replacement right ear pad:
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
crwdns2935229:034crwdne2935229:0
Carsten Frauenheim
146 207 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 867crwdne2935297:0
crwdns2947412:016crwdne2947412:0
This is a great guide!
it is also the solution to the ticking problem on the left ear cup!
there is a small cable linking the microphone to the headset that is beneath the earcup. it has a small holder that should prevent it from moving.
if it’s not attached properly, the noise canceling will start ticking every few seconds in a very annoying way.
removing the earcup and cleaning there is the best solution I found!
Thanks a lot for the amazing guide!!
Sapir Havusha-Laufer - crwdns2934203:0crwdne2934203:0
I was having a similar issue where the right ear cup was making an annoying scratching sound. Turned out to be a hair that was stuck in and brushing against the speaker. Fixed by opening and removing with tweezers!
spencer -
Very comprehensible instructions, thank you! I have rather the problem that the original ear pads are not available anywhere and are not shipped to Germany by Sony. Does anyone have a tip on how to get the replacement pads or any idea which third-party pads can be recommendet?
Larkus Manz - crwdns2934203:0crwdne2934203:0
Where can I buy official replacement earpads?
Arne Vandervorst - crwdns2934203:0crwdne2934203:0
i also need to know that, i found some OEM on amazon, but i don't trust any of them
Nicolas Silva A. -
I don't know where to find the originals but you might want to look into Dekoni earpads, I just recieved mine for the Sony.
Haven't applied them yet but own plenty of other headphones with Dekoni eapads and I'm always satisfied with them.
Ivo Voeten -
Sony outsources the replacement parts to a company named Encompass. https://sony.encompass.com/model/SONWH10...
Francisco Illingworth -
Would be great to see a photo of the BACK side of the earned and the headphones with earpad removed so we know what we are dealing with.
kurt - crwdns2934203:0crwdne2934203:0
Consumable: Ear Pads When you need to replace them, please consult with Sony's consultation window, or with the store where you purchased them.
This is an automatic translation of the Japanese version of the reference guide.
Masakazu Goto - crwdns2934203:0crwdne2934203:0
If you are prying off the ear pads with something too thin you can actually accidentally slide it past the the ear pad and down far enough to catch the next "layer" which is what the ear pad attaches to, so be careful not to pry too hard in case that happens or you risk breaking the plastic. You might have to pull it back up a bit, it should give fairly easy when you have caught just the ear pad.
Oscar Tiderman - crwdns2934203:0crwdne2934203:0
go to sony.encompass.com for the official parts
dahlia - crwdns2934203:0crwdne2934203:0
The aftermarket service provider for Sony products in Germany seems to be "Service Center Baumeister":
https://shop.scbaumeister.de/Ohrpolster-...
They come at a premium price, though.
CalpisWater - crwdns2934203:0crwdne2934203:0
70+56€ for replacement earpads?!?
FelixBan -
Thanks for the Tutorial I wish that sony would make the proper OEM pads available. In my opinion the original ones are the best. I have had my xm4 Headphones for years and would buy them again any day. I have had the annoying screeching problem. I think that i know what it is. I maybe moisture and humidity that gets in and affects the microphones. i wear mine constantly and have for many years. I have noticed a pattern and its moisture. I have spoken to sony and they were great. its not really a fault as far as i can tell. sony could not find OEM ear pads which is a shame all other pads are just not the same.
Superg - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 135
crwdns2936753:07crwdne2936753:0 804
crwdns2936753:030crwdne2936753:0 3,513
crwdns2942667:0crwdne2942667:0 123,459
