Sony WF-1000XM4 Wireless Earbuds battery replacement
  1. Sony WF-1000XM4 Wireless Earbuds battery replacement, Prepare earbud opening: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning this repair, make sure you have completely discharged the battery of the earbud you wish to open. To do this, leave the earbud out of its charging case until the battery is completely discharged.
    • This is a safety precaution to avoid the battery exploding in case of an unintentional short circuit or if too much heat is applied in step 3.
  2. Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove ear tip: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove ear tip: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull on foam ear tip to remove it.
  3. Sony WF-1000XM4 Wireless Earbuds battery replacement, Heat earbud: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a powerful hair dryer or a heat gun, heat the earbud for about ten seconds to soften the glue that sticks both parts of the earbud together.
    • Careful: if you heat the earbud too much, the plastic shell may distort.
    • Heat the earbud all around.
    • This is a difficult step because you need to heat the earbud enough to soften the glue inside the earbud without burning the plastic of the earbud’s shell.
  4. Sony WF-1000XM4 Wireless Earbuds battery replacement, Open the earbud shell: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Open the earbud shell: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Jimmy
    $7.95
    • Take the thinnest possible tool, and slide it into the gap between the two parts of the earbud’s shell.
    • Then, start to lever the two halves apart at the point circled in the picture.
    • If the two parts don’t separate, you’ll need to heat the earbud a little more.
    • When the two parts of the earbud’s shell start to separate, continue to separate them by levering all around the shell.
    • Careful not to burn your fingers as the earbud will be very hot.
    • In the picture I used the iFixit’s Jimmy opening tool, but I think the iFixit’s iFlex Opening Tool is better because it is thinner so it might make this step a bit easier.
  5. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug board-to-board connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug board-to-board connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug board-to-board connector: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the earbud is open, you will see two tiny circuit boards linked by a board-to-board connector.
    • Using an Opening Pick, unplug the two circuit boards by levering very gently between them.
    • Caution: Do not use a metal tool for this step, as the battery is still inside the earbud and you may unintentionally short-circuit components as they are still powered.
    • Set the upper part of the earbud shell aside in order to reassemble it later.
    • The upper part is highlighted in red in the third picture.
    • The lower part is highlighted in dark blue in the third picture.
  6. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unlock the ZIF connector on the lower part circuit board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unlock the ZIF connector on the lower part circuit board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unlock the ZIF connector on the lower part circuit board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ZIF connector on the lower part circuit board.
    • If there is enough room, the battery may be removed without disconnecting the ZIF connector, making this delicate and difficult step obsolete
    • Lift the flap of the ZIF connector using an Opening Pick or another thinner plastic tool.
    • Careful: Do not use a metal tool for this step.
  7. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug the cable of the ZIF connector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug the cable of the ZIF connector: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unplug the cable of the ZIF connector: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an Opening Pick or a spudger, gently unstick the glued cable.
    • Then, gently unplug this cable.
    • It may be a bit difficult to unplug. Take your time, and don’t force it. The cable is fragile.
  8. Sony WF-1000XM4 Wireless Earbuds battery replacement, Unstick circuit board from the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unstick circuit board from the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Unstick circuit board from the battery: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the junction between the electronic circuit and the earbud battery just below it.
    • Using an Opening Pick or a very thin plastic tool, very gently unstick the circuit board from the battery by inserting the Opening Pick between the circuit board and the battery.
    • The circuit board sticks directly to the negative battery terminal with adhesive.
    • Caution: There is a tiny metal contact under the circuit board that makes contact with the battery. Unstick the circuit board gently to avoid damaging this contact.
    • Do not use metal tools in this step as you may short-circuit the battery.
    • Use caution if you decide to heat internal components as the red/white structural plastic will readily deform at low temps.
    • Once the circuit board is unstuck from the battery, lift it up as shown on the third picture to have enough space to remove the battery.
  9. Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by lifting it up using the point of a spudger as shown on the first picture.
    • A bit of force might be required here as the battery is glued to the underside with adhesive.
    This is the way!
    Paul Richardson -
  10. Sony WF-1000XM4 Wireless Earbuds battery replacement, Lift the metal contacts: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Lift the metal contacts: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the two metal contacts
    • One highlighted in red.
    • One highlighted in dark blue.
    • If the contacts were flattened during the battery removal, very carefully lift them up a bit with the point of tweezers so that they will make good contact with the new battery when you reassemble the earbud.
  11. Sony WF-1000XM4 Wireless Earbuds battery replacement, Install new battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Install new battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM4 Wireless Earbuds battery replacement, Install new battery: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install the new battery by placing it in the earbud, negative terminal up.
    • This step can be tricky, as the battery may be attracted by the magnet in the earbud when it is being inserted into the slot.
    • The first picture shows the positive side of the battery.
    • The second picture shows the negative side of the battery.
    • The third picture shows the new battery installed inside the earbud.
To reassemble your earbud, follow these instructions in reverse order from step 8, then glue the two parts of the earbud using E-8000 glue when resealing it.
E-8000 glue is a glue that remains transparent and doesn’t leave drying residues.
crwdns2935229:0242crwdne2935229:0
Brendan
crwdns2935283:009/24/16crwdne2935283:0
52 801 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
This guide helped me fix my xm4's no problem - main tool was a guitar pick, sharpened on some sandpaper. Its good for opening the case, unsticking the tape, opening ZIF connector or usticking the PCB from battery. Just dont push the pick in too deep.
Hard part was reaching the level of heat that makes the glue unbind. First pic in step 4 is a very good hint - the case will get very soft at the point seen on the picture. I had the luxury to use hot air station for heating up. 250°C and mid-high airflow for 10sec at a time, from 4cm distance - still took over 10 tries before i could crack that thing open. Some protective gloves are neccessary.
Marek Błaszczyk - crwdns2934203:0crwdne2934203:0
Hello everyone, it’s my first visit at this site, and article is genuinely fruitful designed for me, keep up posting these types of articles or reviews. CHERRY188
Siluman Babi - crwdns2934203:0crwdne2934203:0
This is a great inspiring article. I am pretty much pleased with your good work.You put really very helpful information. Keep it up. CHERRY188
Just done the replacement and this guide helped amazingly well. One thing to add though is that, even though there is space to remove the battery without taking off the small cable, its very easy to snap that cable accidentally when removing the battery. It worked fine on the first one, but on the second I snapped the cable without even noticing. Don't worry too much if it happens, and DO NOT throw it away. That cable isn't required for the headphones to work, the only thing it seems to affect is it makes the ANC and ambient pass though a little worse. But they still work reasonably well without it.
Howhardcoulditbe - crwdns2934203:0crwdne2934203:0
I wonder if this tool might be good for unsticking without damaging the contacts
https://tinyurl.com/2rbz2k9z
Allen Morrow - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 396
crwdns2936753:07crwdne2936753:0 2,757
crwdns2936753:030crwdne2936753:0 12,952
crwdns2942667:0crwdne2942667:0 393,455
