Sony WF-1000XM3 Main Board Replacement
  1. Sony WF-1000XM3 Main Board Replacement, Earbud Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement, Earbud Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry open the back plate of the earbud.
  2. Sony WF-1000XM3 Main Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws securing the internal components.
    • Both sides of the earbuds are attached with a ribbon cable. Separate the two halves carefully to prevent tearing the cable.
  3. Sony WF-1000XM3 Main Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully remove the battery from the earbud's circuit board.
    • When replacing the battery, make sure to keep the same orientation as the old battery and reconnect the battery to the circuit board.
  4. Sony WF-1000XM3 Main Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the battery and the metal negative contact from the earbud.
    • The battery and the negative contact are secured with double-sided tape, so it may take some force to remove them.
  5. Sony WF-1000XM3 Main Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal negative terminal from the battery.
    • Attach it to the new battery, either with double-sided tape or by placing the new battery and the terminal back into the earbud in the same position they were before.
  6. Sony WF-1000XM3 Main Board Replacement, Main Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement, Main Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Main Board Replacement, Main Board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger and tweezers to remove the small connectors that hold the main board in place.
    • If your device contains soldered components, carefully desolder them with the soldering iron.
    • Gently remove the main board.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
WyattC
crwdns2935283:010/24/24crwdne2935283:0
470 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 3-6, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S3G6
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 789
