Sony WF-1000XM3 Earbud Battery Replacement
  1. Sony WF-1000XM3 Earbud Battery Replacement, Earbud Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement, Earbud Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry open the back plate of the earbud.
  2. Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws securing the internal components.
    • Both sides of the earbuds are attached with a ribbon cable. Separate the two halves carefully so as to not tear the cable.
  3. Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully remove the battery from the earbud's circuit board.
    • When replacing the battery, make sure to keep the same orientation as the old battery and reconnect the battery to the circuit board.
  4. Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the battery and the metal negative contact from the earbud.
    • The battery and negative contact are secured with double-sided tape, it may take some force to remove them.
  5. Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Earbud Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal negative terminal from the battery.
    • Attach it to the new battery, either through double-sided tape or by placing the new battery and the terminal back into the earbud in the same position it was previously.
To reassemble your device, follow these instructions in reverse order. Double-check your work to ensure everything is properly reassembled. Test the earbuds to confirm that the new battery is functioning correctly. If the earbud does not power on, recheck the connections and ensure the battery is connected correctly. Take your e-waste to an R2 or e-Stewards certified recycler.
WyattC
crwdns2935283:010/24/24crwdne2935283:0
458 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 3-6, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S3G6
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 256
crwdns2942667:0crwdne2942667:0 1,267
