Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
  1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
    #1:
    I found pulling with two suckers started to bend the screen as the little clips holding the screen wouldn't release. So instead of risking damage I started to work my way around the edges of the screen by slowly pulling with the sucker and at same time  using the trusty old a spudger tool (Spudger) to gently pry open.
    #2:
    Be care sliding out the ribbon cable connector that goes to the screen. Its also tricky to slide back in after so you might need to peel the ribbon from the back plate to give some more wiggle room. I did.
    GB_Saints_Fan - crwdns2934203:0crwdne2934203:0
    Cracked the screen following the instructions. Too bad I didn’t read the user’s comment. Fortunately it can still be used as normal, though on a white screen the cracks are evident. Good luck doing this .
    Colin Lai - crwdns2934203:0crwdne2934203:0
    The comment is very important.
    #1. Spudger tools should be used together with suction cup.
    #2. Yes. I have small hands and was wondering how anybody with more normal sized hands would be able to do it. I made it but it was a bit tricky.
    grazyna.kosno - crwdns2934203:0crwdne2934203:0
    Poor guide.
    Unfortunately cracked the screen :(
    The guide doesn't mention that there is also glue sticking the front panel to the body; it's very difficult to release the front panel especially around the corners.
    Dr. Gogu - crwdns2934203:0crwdne2934203:0
  4. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip device upward carefully like you are turning the page of a book.
  5. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the camera cable from the device backing.
  6. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3 mm Phillips #000 screw on the left side of the module.
    • Remove the module from the front panel assembly.
Nick Catanzarite
crwdns2935283:009/16/15crwdne2935283:0
188 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Fall 2015 crwdns2935289:0IUPUI, Team 1-2, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S1G2
crwdns2935297:020crwdne2935297:0
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 969
