Sony Vaio Tap 11 Power Jack Replacement
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
    #1:
    I found pulling with two suckers started to bend the screen as the little clips holding the screen wouldn't release. So instead of risking damage I started to work my way around the edges of the screen by slowly pulling with the sucker and at same time  using the trusty old a spudger tool (Spudger) to gently pry open.
    #2:
    Be care sliding out the ribbon cable connector that goes to the screen. Its also tricky to slide back in after so you might need to peel the ribbon from the back plate to give some more wiggle room. I did.
    GB_Saints_Fan - crwdns2934203:0crwdne2934203:0
    Cracked the screen following the instructions. Too bad I didn’t read the user’s comment. Fortunately it can still be used as normal, though on a white screen the cracks are evident. Good luck doing this .
    Colin Lai - crwdns2934203:0crwdne2934203:0
    The comment is very important.
    #1. Spudger tools should be used together with suction cup.
    #2. Yes. I have small hands and was wondering how anybody with more normal sized hands would be able to do it. I made it but it was a bit tricky.
    grazyna.kosno - crwdns2934203:0crwdne2934203:0
    Poor guide.
    Unfortunately cracked the screen :(
    The guide doesn't mention that there is also glue sticking the front panel to the body; it's very difficult to release the front panel especially around the corners.
    Dr. Gogu - crwdns2934203:0crwdne2934203:0
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the cable and jack assembly.
Alexander Bridges
crwdns2935283:009/16/15crwdne2935283:0
1,217 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Fall 2015 crwdns2935289:0IUPUI, Team 1-2, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S1G2
crwdns2935297:020crwdne2935297:0
I wonder if you have the part number or can supply this power jack?
James Toal - crwdns2934203:0crwdne2934203:0
Yes, Where can I find this replacement part?
mikebeard65 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,948
