Changing a laptop battery is an important aspect of maintaining the device’s overall performance and longevity. Over time, batteries naturally degrade, resulting in shorter usage times, unexpected shutdowns, and reduced efficiency. A worn-out battery can hinder productivity, limit portability, and even strain the laptop’s internal components. Replacing it not only restores reliable power but also enhances the user experience, ensuring the laptop remains a dependable tool for work, study, or entertainment. Regular battery maintenance, including timely replacement, is key to keeping your laptop functioning optimally.
Follow this step-by-step guide to learn how to replace the battery for your Sony Vaio PCG-981L laptop.
Before you begin, make sure to power off your device and unplug the charging adaptor and any connected peripherals.
Place the device on a flat surface.
Rotate the device 90° counterclockwise until the battery cover is in front of you.
The battery cover is located in the lower right side of the device in this new orientation.
Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
In this new orientation, the battery cover is located on the left side.
To remove the battery cover, use your hands to slide it upwards.
Now, carefully remove the battery from the device.
Now, the battery should be completely removed from the device.
Enjoy your new battery. For optimal performance, calibrate your newly installed battery after completing this guide.
