Sony VAIO Notebook Computer PCG-432L Hard Drive Replacement
  1. Sony VAIO Notebook Computer PCG-432L Hard Drive Replacement, Opening up the Notebook Part 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all circled screws with a Phillips 0 screwdriver. The screw by the top left of the fan does not need to be taken out. Place those screws in a safe place for later.
    • Flip the notebook over, and then unlatch the display. Once that’s done, lift up the trackpad and wrist-rest assembly, but be careful as to lift it up slowly as there is a ribbon cable to disconnect. Once you see the ribbon cable, disconnect it gently with your hands because using pliers can weaken the integrity of the cable. Put the assembly aside.
  2. Sony VAIO Notebook Computer PCG-432L Hard Drive Replacement, Removing the Hard Drive part 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws holding the Hard Drive in place. I am missing some screws so I only have to unscrew one screw, but this may differ for you. Place these screws aside in a safe place for later on.
    • Using a Jimmy (preferably) or a butter knife, disconnect the Hard Drive from the Notebook.
    • Grab your old Hard Drive and disconnect the connector on top of the Hard Drive. This may require some force, as seen in the video, but contain the power as to not break the connector!
    • Get your new Hard Drive and put the connector onto the prongs of the new Hard Drive. You will see a little bit of a space between the last two prongs on the left but exclude them from the connector as the Hard Drive will not work properly if connected to those four prongs. Just do exactly what I do in the video.
    • Great work! New let’s reconnect the Hard Drive to the Notebook. Follow what I do in the video.
  3. Sony VAIO Notebook Computer PCG-432L Hard Drive Replacement, Connecting your new Hard Drive part 2: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw the Hard Drive back into place with a Phillips 0 screwdriver and those screws you put aside earlier for the Hard Drive mount.
    • Reconnect the ribbon cable to the appropriate slot. Then just rest the trackpad and wrist-rest onto its proper spot and close the computer.
To reassemble your device, follow step 1 in reverse order. Hope you enjoyed my first guide!
[deleted]
crwdns2935283:008/28/18crwdne2935283:0
27,263 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
And then what, how do I install the operating system?
Centro GNet - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 319
