If your Sony SRS-X55 speaker won't play sound from the auxiliary jack, replacing the I/O board may resolve the problem.
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
Disconnect the battery cable from the motherboard.
Remove the battery.
looks like 2 x 18650 batteries in a heatshrink sleeve..
I need battery and board please
Remove the two Phillips screws from the I/O board.
Remove the front panel to the speaker by pushing on the two tabs in the corners.
It's frustrating knowing this task is pretty easy yet having no idea where to purchase a replacement IO board....
Disconnect the ribbon cable from the I/O board.
Carefully remove the I/O board from the speaker.
Is the I/0 board available, mine is damaged and the took it to repair shop but they are saying it cant be repaired
Where can i get a new i/o board?
Geez, they make it a 'challenge' to get those gaskets under the batt covers off.
Don't make ant immediate plans....call your wife, you're gonna be a little late.
Jim Malina - crwdns2934203:0crwdne2934203:0
I need battery with board please help ??
Kevin Ke - crwdns2934203:0crwdne2934203:0
