If your Sony SRS-X55 speaker won't play sound from the auxiliary jack, replacing the I/O board may resolve the problem.
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
Disconnect the battery cable from the motherboard.
Remove the battery.
Remove the two Phillips screws from the I/O board.
Remove the front panel to the speaker by pushing on the two tabs in the corners.
Disconnect the ribbon cable from the I/O board.
Carefully remove the I/O board from the speaker.
Where can i get a new i/o board?
