Disassembling the back cover of the camera so that we can repair components from the inside.
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Flick the blue switch for the battery to pop out.
Remove the battery from the camera.
Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
Remove the panel.
Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
Gently remove the back cover.
Gracias a toda la gente de Ifixit, muy util esta aplicacion y muy buena gente!!.
My battery stuck in the camera
Farida Easmin - crwdns2934203:0crwdne2934203:0
My battery is stuck in the camera
