This is a step by step guide showing exactly how to replace the batteries located inside the camera. This guide is relatively easy and shouldn't take very much time. If the camera is displaying incorrect battery percentages or dies unexpectedly please check out the troubleshooting guide for assistance.
Flip the camera over to look at the bottom side.
Place thumb on battery cover and slide outward until it springs open.
Wont
spring open
Battery opening will not spring open
Same! What was your resolve?
Remove the batteries.
How do you charge the camera? I’ve tried and I can’t seem to figure it out
crwdns2947412:08crwdne2947412:0
I got the Sony Cyber-shot DSC-H300. I didn't see any battery charge pack in it, only the batteries.
Please I want to know if I'm required to charge the batteries or only replace them when they discharge
This uses AA batteries. I’m sure you could use rechargeable batteries as well but I just replace them
Terri S. -
My battery door won't open. It was working until now. Any suggestions?
For any one with this issue it might mean you batteries might have leaked and you can check if there is any white colored residue at the unlock button if , as with my camera i saw some residue, after using something that will not leave marks to push it to unlock position and try to force it a bit to the side the cover, just enough to push something in the edge of cover and housing on the underside near edge of battery cover hinge , to push out the cover a bit more to the side so it slides out to open it and then lift up , just have to clean out the residue of leaked battery of everything in special metal battery contacts on the battery cover , i am trying to find out if there are any replacement parts to replace the metal battery contacts, as i haven`t seen anything yet here
shydar -
The camera door will no longer spring ooen. Any suggestions?
Does Sony make rechargeable battery packs for this camera?
Maybe you guys are doing it the wrong way! I was trying to open it from the side. I finally opened it from the part next to the hole and it opened immediately. 😭😭
My camera’s batter compartment is corroded due to batteries being left over for a long time, is there a way I can remove the battery compartment to clean it fully?
