Sony Cyber-Shot DSC-W830 LCD Replacement
crwdns2942287:0crwdne2942287:0This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
crwdns2944105:0crwdne2944105:0
Slide the lock at the bottom of the camera to "Open".
Slide the blue clip up and away from the battery.
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Pry the device open with the plastic opening tool.
There is also a small corner piece, coloured the same as camera body, at the battery compartment corner which will also fall out. be careful not to loose it - it’s a bit fidly to fit back when re-assembling, but logcal. The Ifixit tweezers where a great help in locating it back on its pins.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Gently release the button board from the clips.
Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
crwdns2947412:05crwdne2947412:0
hii
plaz help me
pless need a sony dsc-'''''wx''''' 830 display LED
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Sony dsc s2000 model camera need
Display & lens unit
