Sony Alpha A350 : LCD Replacement
  1. Sony Alpha A350 : LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the screen.
    • Unscrew the two Phillips #000 screws on each side of the screen.
  2. Sony Alpha A350 : LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to gently pry open the screen.
    • Continue to push and slide along the edge of the screen.
  3. Sony Alpha A350 : LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the glass screen protector from the LCD.
    • Lift the LCD to expose the ZIF connector.
    Bonjour, mais Comment changer la nappe qui relie l’écran au boîtier? Merci
    agnes bolac - crwdns2934203:0crwdne2934203:0
  4. Sony Alpha A350 : LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the ZIF (zero insertion force)connector (the black bar).
    • Flip the lever up and pull the connector out (Be sure not to yank the connector out to avoid damage).
    • Connect the new LCD and then flip the lever down.
crwdns2935229:08crwdne2935229:0
Sydney Duncan
crwdns2935283:010/10/16crwdne2935283:0
820 crwdns2915208:0crwdne2915208:0
CJLADIES crwdns2935289:0CJLADIEScrwdne2935289:0
Community
crwdns2947412:011crwdne2947412:0
This repair guide seems to show the replacement of a AUO Version of Sony Alpha A350 LCD Replacement. Could someone show how to replace a Sony version of a Sony Alpha A350 LCD Replacement. The two are different. Thanks
David - crwdns2934203:0crwdne2934203:0
David,
if you're still looking to solve this : replacing the AUO version or the Sony version of the LCD is exactly the same. However, things get more complicated when you had a broken AUO and want to replace it with a SONY LCD, or vice versa, because the flex circuit (visible in step 4 ) is different between a AUO and SONY LCD. So without switching the flex circuit, you will not be able to switch the LCD from a Sony to a AUO or from a AUO to a Sony.
Am I making sense ? There are I think 4 versions in total of all flex circuits + components (according to the service manual) : 1 is unique for the AUO, 1 is for the Sony, and the last 1 is for both, but depending on components soldered onto it, it needs to be used for either AUO or Sony.
Switching to AUO makes sense, because prices for a Sony replacement LCD nowadays will cost you more then the complete camera.
AUO LCD's can be found for about 20 - 40 $ . If only you could get hold of the appropriate flex circuit.
Hope this helps.
Regards
lockinvar - crwdns2934203:0crwdne2934203:0
years ago i had attempted to replace the screen with no knowledge and i broke the lever, my question to you is how do i fix it now?
Moriah Foster - crwdns2934203:0crwdne2934203:0
Moriah, I have the same issue. did you solve it ? I have a replacement screen but the ZIF plastic connector is broken. Did you find a way to fix it ?
Leopoldo Bolanos -
This is BS. Thee is only one original screen, which is from Sony. AUO is an aftermarket screen, which isn’t suitable without a new flexcable. So if someone ask you which screen it is, if not replaced in the meantime, it’s always Sony.
R Dolphijn - crwdns2934203:0crwdne2934203:0
I ordered a replacement LCD from China and followed your replacement guide. It came with a long ribbon connection, which I didn’t replace and a the screen with the shorter ribbon connected. The LCD works now, but the brightness of the screen is not normal. Do I have to replace the longer ribbon to correct this? Thanks in advance.
Grangales Yukozaki - crwdns2934203:0crwdne2934203:0
what is the meaning of "AUO"? what is the difference between AUO and Sony version? Can you know with the model which version is the one I have?
Daniel Oliveros - crwdns2934203:0crwdne2934203:0
But where can I get the Sony version? I need to replace mine and I can only find the AUO version for sale. Does any one know where I can get the Sony version please?
natashaecharles - crwdns2934203:0crwdne2934203:0
Has anyone resolved this? I need the Sony replacement lcd part but only seem to be able to find the AUO version available..
Jai acheté un ecran de remplacement mais le levier noir s'est brisé, est-ce possible de changer l'ecran sans ce levier?
melcar760 - crwdns2934203:0crwdne2934203:0
I replaced my LCD and Flex cable with a Sony version. After installation, no picture at all. The only thing I got was the camera motor moving. I checked the other buttons and still nothing. Am I missing something?
J Alcala - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 9,243
