Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 5100 Front Plate Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha 5100 Front Plate Replacement, Front Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha 5100 Front Plate Replacement, Front Plate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 5100 Front Plate Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
    Missing one screw. Pop open flash and there is a sideways screw that must come out.
    Nick P - crwdns2934203:0crwdne2934203:0
  5. Sony Alpha 5100 Front Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 5100 Front Plate Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to gently pop the front plate apart from the body.
Kevin Raggiani
crwdns2935283:010/30/19crwdne2935283:0
444 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 crwdns2935289:0UMass Dartmouth, Team S4-G6, Saloman Fall 2019crwdne2935289:0
UMASSD-SALOMAN-F19S4G6
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - crwdns2934203:0crwdne2934203:0
Step 4 is missing one screw. Pop the flash and there is a screw there sideways that must come out.
crwdns2942667:0crwdne2942667:0 1,590
