This guide shows how to replace the Ethernet Port from the Sonos Playbase, which connects the Playbase to the internet.
crwdns2935267:0crwdne2935267:0Pro Tech Toolkit$63.71
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
Remove the two 18 mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
what good is this without a link to where to buy the part you are replacing?
Rob Wright - crwdns2934203:0crwdne2934203:0
