Sonos Play 1 Tweeter Speaker Replacement
  1. Sonos Play 1 Tweeter Speaker Replacement, Exterior Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement, Exterior Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
    The metal lip doesn’t hold down the metal screen. It’s just a connection/conductor between the inside of the metal screen and the shell against which the motherboard is screwed.
    P-308 - crwdns2934203:0crwdne2934203:0
  4. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Sonos Play 1 Tweeter Speaker Replacement, Sonos Play 1 Top Cover Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
    Easily done- fortunately mine didn't snap…
    Oliver Moor - crwdns2934203:0crwdne2934203:0
    Mi bocina Play1 se conecta a internet pero no se escucha. En el app se ve que está reproduciendo. Si subo o bajo el volumen en la bocina se mueve en el app.
    Lalo - crwdns2934203:0crwdne2934203:0
  8. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Sonos Play 1 Tweeter Speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, remove the grey tape from both sides of the device.
  10. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 9 mm Torx #9 screws.
    • Using a plastic opening tool, detach the rear housing cover from the housing.
    • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
  11. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, grip the connector fixed to the motherboard's audio cable.
    • While pulling on the connector, detach the cable by pressing the connectors release.
  12. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
    • You will now be able to remove the rear housing cover.
    you forgot about the WiFi antennas
    Madison Mehlhose - crwdns2934203:0crwdne2934203:0
  13. Sonos Play 1 Tweeter Speaker Replacement, Mid-Woofer speaker: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
    • Remove the power cable.
    Please add info how and where to connect the wifi antennas on motherboard again
    Jan - crwdns2934203:0crwdne2934203:0
    This is very helpful but I managed to remove the speaker easily without removing the power cable to the motherboard, the power cable to the housing or doing anything to the WiFi connectors.
    andrew.goldsworthy - crwdns2934203:0crwdne2934203:0
  14. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, press the release located in the center of the connector .
    • While pressing the release pull on the connector detaching it from the speaker.
    • Do this for both connections.
  15. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Torx T20 bit remove the four 13 mm screws fastening the speaker to the housing.
    • Remove the speaker by lifting it up towards the top of the housing and out at an angle.
    how do you replace the screw with the magnet nearby???
    Ernst Wallinga - crwdns2934203:0crwdne2934203:0
    Does anyone know where to get a replacement speaker?
    Bryan Martinez - crwdns2934203:0crwdne2934203:0
    On the front seal of the speaker driver there is some ID, and there are some lots of pre-owned drivers by that id on AliExpress. They are super expensive though, so it may be easier to get an old full size power speaker from Technics or other and upscale your SONOS by wiring it to the large speaker (there are two channels: one for low/mid frequencies and another for high freq).
    Vadim Karp - crwdns2934203:0crwdne2934203:0
    Hallo zusammen,
    wo gibt’s nen Ersatzwoofer? Ich finde nix.
    Adrian - crwdns2934203:0crwdne2934203:0
  16. Sonos Play 1 Tweeter Speaker Replacement, Tweeter Speaker: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement, Tweeter Speaker: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, press down on the clips that lock the input wires to the amplifier.
    • Once unlocked, pull back on the wires to remove them.
  17. Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Tweeter Speaker Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a screwdriver, remove the four 10 mm Torx Security #10 screws.
    • Using your fingers, remove the tweeter from the front of the housing.
Gregory Klein
crwdns2935283:008/27/15crwdne2935283:0
704 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-4, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-4, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G4
Can anybody recommend a source for a replacement tweeter speaker with comparable specs? Unless I missed something, this article doesn't address that, and that's kind of an important piece of the puzzle.
John Martinez - crwdns2934203:0crwdne2934203:0
You can get them from Aliexpress for about 10€.
Stanton Attree - crwdns2934203:0crwdne2934203:0
How do I look for the speaker replacement, what characteristics should I indicate because I can't find it, greetings
Gerardo Arguedas - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 9,437
