Sonos Play 1 Motherboard Replacement
  1. Sonos Play 1 Motherboard Replacement, Exterior Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement, Exterior Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
    The metal lip doesn’t hold down the metal screen. It’s just a connection/conductor between the inside of the metal screen and the shell against which the motherboard is screwed.
    P-308 - crwdns2934203:0crwdne2934203:0
  4. Sonos Play 1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Sonos Play 1 Motherboard Replacement, Sonos Play 1 Top Cover Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Sonos Play 1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
    Easily done- fortunately mine didn't snap…
    Oliver Moor - crwdns2934203:0crwdne2934203:0
    Mi bocina Play1 se conecta a internet pero no se escucha. En el app se ve que está reproduciendo. Si subo o bajo el volumen en la bocina se mueve en el app.
    Lalo - crwdns2934203:0crwdne2934203:0
  8. Sonos Play 1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Sonos Play 1 Motherboard Replacement, Disassembling Sonos Play 1 Rear Housing Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement, Disassembling Sonos Play 1 Rear Housing Cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, remove the grey tape from both sides of the device.
  10. Sonos Play 1 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 9 mm Torx #9 screws.
    • Using a plastic opening tool, detach the rear housing cover from the housing.
    • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
  11. Sonos Play 1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, grip the connector fixed to the motherboard's audio cable.
    • While pulling on the connector, detach the cable by pressing the connectors release.
  12. Sonos Play 1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
    • You will now be able to remove the rear housing cover.
    you forgot about the WiFi antennas
    Madison Mehlhose - crwdns2934203:0crwdne2934203:0
  13. Sonos Play 1 Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6 mm Torx #6 screws securing the communications board to the motherboard.
    • Using your fingers, detach and remove the communications board from the motherboard.
    • Be sure to keep the communications board parallel to the motherboard when removing as to prevent damage to the connector.
  14. Sonos Play 1 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 1 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 10 mm Torx #10 screws fastening the motherboard to the rear housing cover.
    • Using a plastic opening tool, remove the motherboard from the rear housing cover.
crwdns2935229:09crwdne2935229:0
Margarita
crwdns2935283:009/03/15crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-4, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-4, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G4
crwdns2947412:015crwdne2947412:0
Where do you get these replacement parts from - not directly from Sonos I understand.
iou_james - crwdns2934203:0crwdne2934203:0
…by the way I am looking for a new motherboard for a Sonos Play1 unit.
On a Play 1 r524 and r525 are blown. What are these.and how do I get replacements
houser_m.d - crwdns2934203:0crwdne2934203:0
Same here. r524 and r525 look blown. Have you been able to identify their values? Did you find any further damage? Have you been able to repair it?
Oliver Krause -
The parts has 1R00 printed on them. 1R= 1 Ohm resistor. You can open an old electronic gadget or look at an old PC-motherboard and see if you find one there. It’s normally hard find surface mounted resistors in local stores…
Patrick Tollgren lazarov -
Did anyone find out where Sonos play 1 parts can be purchased from?
Dawn - crwdns2934203:0crwdne2934203:0
I have two blown components. Here is a screenshot https://web.capture-app.com/share/d77cb9...
And here is the place on the motherboard from the picture in this guide. https://web.capture-app.com/share/89a940...
I cant see any other blown components on my board.
Anyone knows what the components are?
Patrick Tollgren lazarov - crwdns2934203:0crwdne2934203:0
I have a Sonos Play 1 with also R524 and 525 blown. I see on a ‘good’ board that both these SMD resistors are 1R10, that’s 1,1 ohm. Did somebody had succes in replacing the 2 resistors resulting in a working Sonos Play 1?
Rob Korver - crwdns2934203:0crwdne2934203:0
has anyone tried adding a “line in “ for those?
Jarek Pawlega - crwdns2934203:0crwdne2934203:0
I am looking for a component value for C303 on the Play:1 motherboard. It is (was) a 1206?? surface mount capacitor on the bottom side of the motherboard to the left of the Ethernet port. It is cracked crumbled and charred so I think replacing it may bring life back to the device. If anyone can provide the value, greatly appreciated!
Jonathan Wescott - crwdns2934203:0crwdne2934203:0
Still not any wiser on where to get a new motherboard?
magnusson80 - crwdns2934203:0crwdne2934203:0
the R178 resistor on my board went dead. Anyone can look it up on their sonos 1
Loo Harmless - crwdns2934203:0crwdne2934203:0
r178 is located on the other side, just underneath the most blown resistors R525 , R423 and R524
I see still nobody has a clue where to buy a new motherboard for the sonos play 1?
Please advice?
Jozef Bakker - crwdns2934203:0crwdne2934203:0
Hello,
What are the values / refs of TH301 & MOV301 ? It is near the AC input
Thx for your answer
Br Roland
Roland Platteau - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 196
crwdns2942667:0crwdne2942667:0 22,482
