Smoke Detector Battery Replacement
crwdns2942287:0crwdne2942287:0Smoke detectors are used to keep homes safe from fire. A beeping smoke detector means that it is time for a new battery. This guide will walk users through the steps of replacing a battery in a home smoke detector.
Remove the smoke detector from the ceiling by twisting the smoke detector counter-clockwise.
Open the battery compartment in the back of the smoke detector.
Lift the battery out of the battery compartment.
Push the red switch down with your finger.
Place the new battery on top of the red switch.
Push the new battery into the battery compartment.
Don't want to replce smoke detector battery frequently, you can try Ultrable 10-year long life 1200mAh 9V lithium battery at http://www.ultrablecell.com/en/Products/....
